Adding keys to keyframes using Select>All does not work as expected
Hi All my friends, I am here with a very naive (and possibly easy to solve) problem. I go by the concrete example immediately to make things clearer.
Use Rebekah for V8 plus other products which you can easily recognize.
Time frame 0, get this:
Then Select>All, Add key to frame 0 after selecting all in the scene, change to time frame 1, do some random pose and note that I do not move her thighs:
Then Select>All, Add key to frame 1 after selecting all in the scene, change to time frame 2, other random poses, this time moving thighs as well, repeat to time frame 3:
Now GO BACK to time frame 1, and surprise:
Now that I go back to time frame 1, thighs moved (compare with the TEST 1 above in which I have not moved the thighs at all). When I was on time frame 1 I already selected all and added the key on the timeline, so I expected that changing the position of her thights in frame 2 and 3 would have not affected time frame 1, but apparently this is not the case.
How can I solve this problem? Thanks in advance? Irene
I noticed that the pictures do not show properly so let me try with the links:
TEST 0: https://www.deviantart.com/justfordazforum/art/Test0-829034171
TEST 1: https://www.deviantart.com/justfordazforum/art/Test1-829034212
TEST 2: https://www.deviantart.com/justfordazforum/art/Test2-829034228
TEST 3: https://www.deviantart.com/justfordazforum/art/Test3-829034248
TEST 1 AFTER: https://www.deviantart.com/justfordazforum/art/Test1after-829034264
