Morph explodes, or more implodes, clothes
Trying to figure out how to morph clothing. I export base obj, edit in blender then export out of blender. Morph loader pro loads the morph with no errors, but when I use the slider to apply the morph it just shrinks and wrinkles the entire peice of clothing like a wadded up tissue. It does this to the entire figure even if the morph created in blender only effects a small area of the mesh.
It looks a lot like if you exploded clothing in a dforce simulation. Except instead of exploding it into a larger mass it, I guess implodes is the best description, into a smaller crinkled mass.  What am I doing wrong?
Thanks
  • felisfelis Posts: 6,513
    In Blender you must only use operations that moves the vertices.
    Anything else will mess up the vertex order, and then DS will calculate a totelly different effect.
    Have you previously succesfully made a morph?
    If not, maybe try to do a simple morph, to check your workflow.
  • 3WC3WC Posts: 1,165
    Yes, it is very important to check "Keep vertex order" when importing or exporting.
  • TheKDTheKD Posts: 2,711
    I had the same thing happen exporting a simulated dforce dress, then importing it back in as a morph lol. When I dialed up the morph, the dress like crumpled to the floor into a ball lol.
  • sajikysajiky Posts: 28
    Thanks for the responses. I actually figured it out right before I checked back here lol. It was that I didn't have "Keep Vertex Order" selected when importing into Blender.
