MICK Question
Is there a way to move the components of the MICK without the snap?  Would like to fine tune some positions.
  • OdaaOdaa Posts: 1,548
    I've played a little with the Gothic Church cousin to this kit, and just selecting the component and using the translation/rotation dials under Parameters seemed to work fine.
  • NorthOf45NorthOf45 Posts: 5,920
    The dials are hidden by default, so you need to unhide them. Right-click on the Parameters tab, or click on the pane options menu, and select "Show Hidden Properties". You can also just use the manipulator tool(s) in the viewport. With those, you can set your own snapping level with the Tool Settings tab.
  • Thanks for the help.
