Unable to import image files into surface nodes in Daz Studio Pro.
edited January 2020 in Daz Studio Discussion
I've just reinstalled Daz Studio to the latest version (4.12 Pro) on my iMac running Catalina. I can open any model but if I want to import/change any image files (JPGs, PNGs etc) into the surface nodes (texture, bump etc) all the files are greyed out/unselectable when I open the mac desktop window and will not load into Daz Studio. Does anyone have a solution? Thank you.
Post edited by ukburn4_82a1db70af on
  • I assume you mean the latest Geneal release, 4.12.0.86, rather than the atest Public Build, 4.12.1.55, as the latter has a fix for the file dialogue issue https://www.daz3d.com/daz-studio-beta
  • edited January 2020
    I was going to give it a go, but noticed that this public build is 32 bit. My current install is 64 bit
  • I was going to give it a go, but noticed that this public build is 32 bit. My current install is 64 bit
    Both should be avalable, otherwise we couldn't use Iray. Check your download filters in Install Manage are set to show 64 bit software.
