Just Diffuse Maps (iray)
I'd like to be able to select every item in my scene and apply a shader that removes everything but the diffuse maps. I looked but didn't find a product that would do that. Maybe there's a script somewhere? Thanks.
  • Just set up a material with no maps assigned, File>Save As>Shader Preset, uncheck Diffuse in the options dialogue (and if you want to leave the values alone use the dialogue's menu, the lined button half-way down on the right, to select Maps only). In future select the onject(s) and their surfae(s) and double-click the preset (or right-click on it and select Create Custom Action to add it to the Scripts menu for qucik access).
  • Thanks Richard. I tried that, but couldn't get it to work. I'll keep trying.
  • No matter what I try, I can't seem to make a shader that overrides all of the existing surface settings.
  • Are you just wanting to clear the maps? Are the surfaces using the same base shader?
  • What do you mean by clear the maps? The surfaces in the scene are all different. Thanks for helping me work this out.
  • Here's what's happening: I select everything in the scene tab; highlight everything in the surfaces tab; control-click a shader and keep diffuse maps; see below where there are question marks in the channels indicating there's more than one setting? The shader is working, but some of the surfaces act like they're locked.
    457 x 1080 - 272K
  • I see, not sure what is going on there.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,872
    scene optimiser can do this
    https://www.daz3d.com/scene-optimizer
  • Ooo, really? I own it, but haven't had the occasion to use it yet. Thanks, I'll give it a try.
