Obj clothing from cgtrader?
cguernelli
Hi,
Someone knows if i can use obj clothing from cgTraders and add to my model in DAZ?
Attached a example.
Female Tracksuit
Thank you
Hi,
Attached a example.
Female Tracksuit
Thank you
If you can line it up wth the figur you want to use it on then yes, via dForce as long as it is constructed in a way that works. If you want to/need to rig it (for example if it falls apart uner dForce) then you would need to adjust the model so that it fitted in its zero state around the zeroed figure, then use the Transfer Utility. There isn't a definite answer to be given in general, or (unless it's obviosuly a hopeless case) from looking at a single product page (so since the product page isn't informative and is off-site commercial I have removed the link)
If the gamrnet isn't rigged for a particular figure it is a massive PITA to get it to fit in DS.
Importing an .obj prop is pretty easy.
