Texture Tiling Problem
in New Users
Hello!
I'm attempting to make new textures for the Blazer in the "Formal MEGA Wardrobe for Genesis 8 Females" Package. Using the provided Template I made a custom texture map - which displays perfectly in the Preview window - however when I render it the Texture seems to shrink considerably and become tiled across the surface. (see attached Image)
After searching the forums for a solution - I set the Horizontal and Vertical Tiling to 1, but the Render still comes out like it is on the right pic.
Can anyone help please?
Thanks!
769 x 645 - 60K
There are wo tiling settings - one on th surface as a whole and, for the Iray Uber Base, one in the Image Editor for each map - click the micro thumbnail to open the image picker menu to access the Image Editor (not the Layered Image Editor).
Aha! Found it! Thank you very much!
