Problem with importing obj
Hi, all.
I need to export the character to .obj and then re-import it into daz. Before that, I used this method quite often. Today again there is a need to do something similar, but instead of the correct import, the character has inverted normals and is in a different position. The export/import settings have not changed since the last successful import.
In addition, there were problems with using obj as a morph when working with morph loader pro.
788 x 877 - 112K
Have you done anything with the OBJ file between the export from DS and the re-import into DS?
What are your OBJ import settings in DS?
What version of DS are you using? I am using 4.12 and don't see any such problems with an export then re-import with nothing done to the file in between.
I didn't do anything with the file between export and import.
Throughout the day, I tried different export and import options. The problem persisted with various settings. At the same time, there were cases when the import settings were unchanged, the result was the same as in the picture and sometimes it was correct. I don't understand why with the same export/import settings, the end result can change.
After that, I decided to just reinstall daz. After reinstalling, the problems disappeared, at least for now.
Well, that sounds very strange. At least the re-install fixed it.
