Previous Figures Export Script
I still occasionally enjoy working with both Genesis and Genesis 2 figures.  (It takes about 1/3 of the time to pose)
However, when exporting the obj for sculpting in either mudbox or ZBrush the UV's export all stacked into the first tile.  G3 & G8 export with each map on a different tile.
Does anyone know of an export script or any product with an export script that will spread the UV maps over different tiles?
  • It doesn't actually matter - the UVs are stacked in t base mesh, before yu sculpt it, anyway. If you want to separate them I believe Mudbox can do the job, as can just about any other modeller - you simply need to select all the surfacs that belong on a map and move them a whole number of units, usually along the U axis.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,872
    there are UDIM UV's for the earlier figures on shareCG
  • there are UDIM UV's for the earlier figures on shareCG
    I could just kiss you right now!!!!!!
    Have looked for this in Mudbox but haven't found a way to get it done.  Wanted to say thanks for the response because you're always helpful and I hope you get paid for this!!
