Working with maps
With the function getAllMaps() and by iterating through them allMaps[i].name I am able to output all map names, but how do I know for what these maps are used?
Or seen differently: getColorMap() seems to return the diffuse color map, but how can I get the maps for glossiness, normals, bump maps, etc.?
Thank you!
Have you looked at this sample script http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/properties/material_properties/start ?
Thanks for your help! I am new to DAZ scripting and all other java script like languages in general. The script looks fairly complicated for what I thought should be relatively simple. I guess one of the first points I don't get is the property stuff. As far as I can seel the script searches for a property name:
var sPropertyName = "UV Set";
But how do I get all available property names (normal map, opacity, etc.) so that I can search for them?
The script prints stuff like
- DzUberIrayMaterial "Torso" :: DzEnumProperty (/Geometry/UV Maps/UV Set) "UV Set"
- DzUberIrayMaterial "Face" :: DzEnumProperty (/Geometry/UV Maps/UV Set) "UV Set"
How do I would I get the associated names of the maps (i.e., the names of the linked .jpg textures for diffuse, normal, roughness, etc.) that I get with getAllMaps()?
Many thanks!
To get a property name, click the gear icon on its slider and select Parameter Settings - the dialogue gives both label and name, for this you want name.
