When clothes appear as grey cubes, why?
blue6stringblue6string Posts: 60
Why does this happen at times and how do you undo it? If you delete the clothes and add them again to scene/character they come in again as cubes. This seems to happen randomly and just often enough to be annoying...
  • mark128mark128 Posts: 1,033
    This usually means the geometry files are missing.
    Are you getting error messages about missing files when you load them?
    Are these V4/M4 clothes being auto fitted to Genesis 1/2? V4/M4 clothes on v4/M4? Genesis clothes on Genesis?
    Have you moved or rearranged any directories in you content libraries?
  • blue6stringblue6string Posts: 60
    G2 clothing for G2 character.
    It appears after file the anumber of renders may have been made etc... without any swapping in and out of characters etc. I just open the scene and there are cubes.... Most times I can step back to a previous scene but saved as a different file name... and things load fine.
    Sometimes I do get a an error message regarding location. But I'm a little confounded as I barely know where those files are and I don't shuffle that stuff.
    Have you checked the log file Help > Troubleshooting > View Log File
    What scene format are these, DAZ or DUF?
    I will try that.... and report back
    Always Duf... I didn't know that there a choice to save in another format
    problem gone... the only thing that has changed is that I restarted my computer a few hours back... maybe it's a hardware issue??
    What kind of drives/partitions do you have? What operating system?
    I could see it happening if some of the folders are on a separate drive/partition/network storage device that isn't available/has spun down.
    DAZ is the older format, and is saved a different way. You can't save as DAZ in the newer versions, I was just checking.
    win8
    i have one external dinosaur driver (dont use it anymore)
    2 hhd hard drives, and 2 ssd drives...
    So should things be where both scenes and program operating system are on comparable drives
    My guess is that what ever folder they are in is on a drive that is "spinning down"/'sleeping' so when it is being run the cached files can't be found. But restarting/rebooting will clear and repopulate the cache, so will loading in a new scene (same content, different name...different cache 'folder').
    This is an OS level problem...so check your timeouts/sleep times in Windows...try "NEVER" for any disk based drives and whatever the SSD manufacturer recommends on all SSDs.
    Aww...makes sense! Thanks for the answer you are spot on....
