Reflection Designer
Kev914Kev914 Posts: 1,148
I tried to use this product, but I can't get it to work. Maybe I just don't understand what I am suppose to do. But just to test it out, I added a figure to my scene, then I added a primitive plane and positioned it to the side of the figure. Then I used the geometry editor to select a polygon on the plane. (There were 30 devisions.) Then I ran the man script. I can change all the settings. Add a light from the scroll bar at the top. I can move the camera. But what I can't do is click on ACCEPT. No what mater changes I make, the accept bottom never becomes available. So what am I doing wrong?
Thanks.
  • TaozTaoz Posts: 10,373
    Have you watched the video on the product page?
  • Kev914Kev914 Posts: 1,148
    Yes. Thanks. I watched the video. I went back and tried it again this time with a figure and a sphere. But I got the same result. Everything seems to work except the ACCEPT button never becomes active. In the video, it becomes active as soon as they add one of the lights from the bar at the top. What I've described  is what happens with the main script. However, there are two other scripts that adjust the light or the camera. Both of those work. As soon as I open them, the ACCEPT button is already active. I assume that is because I have used the main script to add the light. Maybe there is some step I am missing with the main script, but I just don't see what it is.
    So the main script doesn't work right because the accept button remains greyed out. But the two other scripts work as they are suppose to.
  • Can you post the log?
    BTW, the official support thread is here: https://www.daz3d.com/forums/discussion/354171/released-reflection-designer-commercial#latest
    edited December 2019
    Hi. I tried it again today and the same thing happens.The product works as the screen shot will show. I just can't add the settings to my scene because the active button never becomes active. For this test, I just added the first light. Before I started, I cleared the log. I tried to post the full log below, but the tx file wouldn't upload. And the forum said it was too large to just past, so what is shown below is the end of the file. Also, I did not get any error except at the end when I canceled the script.
    1160 x 799 - 721K
    Post edited by Kev914 on
    2019-12-10 08:32:52.213 Iray [VERBOSE] - IRAY:RENDER ::   1.8   IRAY   rend stat : Geometry memory consumption: 10.7993 MiB (device 0), 0 B (host)
    2019-12-10 08:32:58.116 Iray [INFO] - IRAY:RENDER ::   1.7   IRAY   rend info : Importing lights for motion time 0
    2019-12-10 08:32:58.116 Iray [INFO] - IRAY:RENDER ::   1.7   IRAY   rend info : Initializing light hierarchy.
    2019-12-10 08:32:58.117 Iray [INFO] - IRAY:RENDER ::   1.7   IRAY   rend info : Light hierarchy initialization took 0.001s
    2019-12-10 08:32:58.244 Iray [VERBOSE] - IRAY:RENDER ::   1.7   IRAY   rend stat : Native CPU code generated in 0.123s
    2019-12-10 08:32:58.244 Iray [INFO] - IRAY:RENDER ::   1.6   IRAY   rend info : CPU: Scene processed in 6.042s
    2019-12-10 08:32:58.244 Iray [INFO] - IRAY:RENDER ::   1.7   IRAY   rend info : CPU: Allocated 702.984 KiB for frame buffer
    2019-12-10 08:32:58.277 Iray [VERBOSE] - IRAY:RENDER ::   1.8   IRAY   rend stat : Texture memory consumption: 678.565 MiB for 43 bitmaps (device 0)
    2019-12-10 08:32:58.278 Iray [VERBOSE] - IRAY:RENDER ::   1.8   IRAY   rend stat : Lights memory consumption: 1.72266 KiB (device 0)
    2019-12-10 08:32:58.278 Iray [VERBOSE] - IRAY:RENDER ::   1.8   IRAY   rend stat : Material measurement memory consumption: 0 B (GPU)
    2019-12-10 08:32:58.382 Iray [VERBOSE] - IRAY:RENDER ::   1.8   IRAY   rend stat : PTX code (126 KiB) for SM 6.1 generated in 0.104s
    2019-12-10 08:32:58.383 Iray [VERBOSE] - IRAY:RENDER ::   1.8   IRAY   rend stat : Materials memory consumption: 187.02 KiB (GPU)
    2019-12-10 08:32:58.636 Iray [INFO] - IRAY:RENDER ::   1.8   IRAY   rend info : JIT-linking wavefront kernel in 0.253s
    2019-12-10 08:32:58.824 Iray [INFO] - IRAY:RENDER ::   1.8   IRAY   rend info : JIT-linking mega kernel in 0.188s
    2019-12-10 08:32:58.824 Iray [INFO] - IRAY:RENDER ::   1.16  IRAY   rend info : CUDA device 0 (GeForce GTX 1080): Scene processed in 6.622s
    2019-12-10 08:32:58.826 Iray [INFO] - IRAY:RENDER ::   1.8   IRAY   rend info : CUDA device 0 (GeForce GTX 1080): Allocated 11.6551 MiB for frame buffer
    2019-12-10 08:32:58.826 Iray [INFO] - IRAY:RENDER ::   1.16  IRAY   rend info : CUDA device 0 (GeForce GTX 1080): Allocated 1.6875 GiB of work space (2048k active samples in 0.000s)
    2019-12-10 08:32:58.826 Iray [INFO] - IRAY:RENDER ::   1.16  IRAY   rend info : CUDA device 0 (GeForce GTX 1080): Used for display, optimizing for interactive usage (performance could be sacrificed)
    2019-12-10 08:32:58.930 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00001 iterations after 6.716s.
    2019-12-10 08:32:58.935 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:32:58.935 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2019-12-10 08:32:59.099 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00003 iterations after 6.880s.
    2019-12-10 08:32:59.101 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:32:59.264 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00005 iterations after 7.045s.
    2019-12-10 08:32:59.266 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:32:59.412 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00007 iterations after 7.193s.
    2019-12-10 08:32:59.414 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:32:59.598 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00009 iterations after 7.379s.
    2019-12-10 08:32:59.600 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:32:59.705 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00011 iterations after 7.487s.
    2019-12-10 08:32:59.707 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:32:59.856 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00013 iterations after 7.637s.
    2019-12-10 08:32:59.857 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:32:59.980 Iray [INFO] - IRAY:RENDER ::   1.8   IRAY   rend info : CPU: Allocated 5.24553 MiB for frame buffer
    2019-12-10 08:32:59.982 Iray [INFO] - IRAY:RENDER ::   1.7   IRAY   rend info : CUDA device 0 (GeForce GTX 1080): Allocated 7.09604 MiB for frame buffer
    2019-12-10 08:32:59.987 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00015 iterations after 7.768s.
    2019-12-10 08:32:59.989 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:00.284 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00017 iterations after 8.065s.
    2019-12-10 08:33:00.286 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:00.426 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00018 iterations after 8.207s.
    2019-12-10 08:33:00.428 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:00.567 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00019 iterations after 8.348s.
    2019-12-10 08:33:00.569 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:00.693 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00020 iterations after 8.474s.
    2019-12-10 08:33:00.695 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:00.849 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00021 iterations after 8.630s.
    2019-12-10 08:33:00.851 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:00.992 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00022 iterations after 8.773s.
    2019-12-10 08:33:00.993 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:01.132 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00023 iterations after 8.913s.
    2019-12-10 08:33:01.133 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:01.279 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00024 iterations after 9.060s.
    2019-12-10 08:33:01.281 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:01.418 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00025 iterations after 9.199s.
    2019-12-10 08:33:01.420 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:01.569 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00026 iterations after 9.350s.
    2019-12-10 08:33:01.571 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:01.712 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00027 iterations after 9.493s.
    2019-12-10 08:33:01.714 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:01.853 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00028 iterations after 9.634s.
    2019-12-10 08:33:01.855 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:01.969 Iray [INFO] - IRAY:RENDER ::   1.7   IRAY   rend info : CPU: Allocated 3.98615 MiB for frame buffer
    2019-12-10 08:33:01.981 Iray [INFO] - IRAY:RENDER ::   1.5   IRAY   rend info : CUDA device 0 (GeForce GTX 1080): Allocated 8.35542 MiB for frame buffer
    2019-12-10 08:33:01.983 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00029 iterations after 9.763s.
    2019-12-10 08:33:01.984 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:02.087 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00030 iterations after 9.868s.
    2019-12-10 08:33:02.088 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:02.233 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00032 iterations after 10.014s.
    2019-12-10 08:33:02.235 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:02.395 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00034 iterations after 10.176s.
    2019-12-10 08:33:02.397 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:02.694 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00038 iterations after 10.475s.
    2019-12-10 08:33:02.696 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:03.229 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00046 iterations after 11.011s.
    2019-12-10 08:33:03.231 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:04.304 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00061 iterations after 12.086s.
    2019-12-10 08:33:04.306 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:05.548 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00078 iterations after 13.329s.
    2019-12-10 08:33:05.550 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:06.868 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00096 iterations after 14.649s.
    2019-12-10 08:33:06.870 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:08.284 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00115 iterations after 16.065s.
    2019-12-10 08:33:08.286 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:09.852 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00136 iterations after 17.633s.
    2019-12-10 08:33:09.854 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:11.480 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00159 iterations after 19.262s.
    2019-12-10 08:33:11.482 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:13.403 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00186 iterations after 21.184s.
    2019-12-10 08:33:13.404 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:15.126 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    2019-12-10 08:33:15.459 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00215 iterations after 23.240s.
    2019-12-10 08:33:15.461 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:17.777 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00247 iterations after 25.558s.
    2019-12-10 08:33:17.779 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:20.299 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00282 iterations after 28.081s.
    2019-12-10 08:33:20.301 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:22.998 Iray [INFO] - IRAY:RENDER ::   1.5   IRAY   rend info : CPU: Allocated 3.39201 MiB for frame buffer
    2019-12-10 08:33:23.003 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00320 iterations after 30.784s.
    2019-12-10 08:33:23.005 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:23.026 Iray [INFO] - IRAY:RENDER ::   1.17  IRAY   rend info : CUDA device 0 (GeForce GTX 1080): Allocated 8.94956 MiB for frame buffer
    2019-12-10 08:33:25.582 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00362 iterations after 33.363s.
    2019-12-10 08:33:25.583 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:28.737 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00419 iterations after 36.518s.
    2019-12-10 08:33:28.739 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:32.548 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00483 iterations after 40.330s.
    2019-12-10 08:33:32.550 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:36.456 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00551 iterations after 44.237s.
    2019-12-10 08:33:36.458 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:40.878 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00627 iterations after 48.659s.
    2019-12-10 08:33:40.880 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:45.657 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00710 iterations after 53.438s.
    2019-12-10 08:33:45.658 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:50.838 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00802 iterations after 58.619s.
    2019-12-10 08:33:50.840 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:33:56.713 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00904 iterations after 64.495s.
    2019-12-10 08:33:56.715 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:34:03.045 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 01016 iterations after 70.826s.
    2019-12-10 08:34:03.046 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:34:10.197 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 01140 iterations after 77.978s.
    2019-12-10 08:34:10.201 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2019-12-10 08:34:18.186 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
    2019-12-10 08:34:18.186 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (GeForce GTX 1080):      1140 iterations, 6.767s init, 78.926s render
    2019-12-10 08:34:18.187 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU:      1276 iterations, 6.061s init, 79.185s render
    2019-12-10 08:34:25.566 DEBUG: ExecutePB
    2019-12-10 08:34:25.566 DEBUG: Found button 1
    2019-12-10 08:34:25.567 DEBUG: filename Z:/Daz Content/Daz Studio DIM/Data/Half Life/Reflection Designer/Presets/Reflection Light Planes/Automotive Overhead 02.duf
    2019-12-10 08:34:27.042 File loaded in 0 min 1.4 sec.
    2019-12-10 08:34:27.043 Loaded file: Automotive Overhead 02.duf
    2019-12-10 08:34:27.190 DEBUG: new fill Reflection Light Plane
    2019-12-10 08:34:27.193 DEBUG: SetFillProperties Reflection Light Plane pSphere(11cg000)24_12_zpos
    2019-12-10 08:34:27.193 DEBUG: Using hack to get selected facets
    2019-12-10 08:34:27.193 DEBUG:       Index: 122
    2019-12-10 08:34:27.193 DEBUG: SetFillProperties 122
    2019-12-10 08:34:27.194 DEBUG: MoveReflection [object Object] [12.5,70.8799,52.3486] [0.234222,0.565462,-0.790818] 100 undefined
    2019-12-10 08:34:27.194 DEBUG: AimFillProp Reflection Light Plane true
    2019-12-10 08:34:27.194 DEBUG:        [12.5,70.8799,52.3486]
    2019-12-10 08:34:27.194 DEBUG: Align Plane Reflection Light Plane [-33.8824,131.239,-12.5007] [12.5,70.8799,52.3486] ZPos [object Object]
    2019-12-10 08:34:38.941 WARNING: Script Error: Line 331
    2019-12-10 08:34:38.941 WARNING: ReferenceError: Can't find variable: GetLightProperty
    2019-12-10 08:34:38.941 WARNING: Stack Trace:
        <anonymous>()@Z:/Daz Content/My Daz Connect Library/data/cloud/1_64155/scripts/riversoft art/reflection designer/reflection designer.dse:331
    2019-12-10 08:34:39.672 Error in script execution: Z:/Daz Content/My Daz Connect Library/data/cloud/1_64155/scripts/riversoft art/reflection designer/reflection designer.dse
    Ok, that is strange.  It cannot find the GetLightProperty function.  This function should be in the Data/RiverSoft Art/Common/Photography/RSAutoFillFunctions.dse file.  It sounds like a Connect installation error.  Can you check that this file exists on your system?
    Yes. The file is there. I just tried uninstalling the Daz Connect version and then installing using DIM, but the same thing happens. I can get it all to work, except I don't get the accept button.
  • LeanaLeana Posts: 13,631
    Which version of DS do you use?
    I am using 4.12.
    I also tried a manuel install and I get the same result: Everything seems to work except that the ACCEPT button is unavailable on the main script. When I run the other two scripts, everything works fine. The ACCEPT button is available as soon as the other two scripts open.
    After the uninstall of the connect version, I went in and removed the folder for this product. It was probably unnecessary because all the folders were empty. But just to be sure that it wasn't an issue, I moved the empty folders for this product out of the cloud folder.
    693 x 231 - 12K
  • KevinH said:
    I am using 4.12.
    The accept button doesn't work because that part of the script actually STOPS when the error occurs.  Do you have Lighting Designer by any chance?  If you uninstall that, does Reflection Designer work?  If you search your HD, are there multiple copies of the RSAutoFillFunctions.dse?  The script might be pulling in an old one.
    I have Lighting Designer. I uninstalled it and now I get the Accept button. Thanks.
    Does that mean I can't have Lighting Designer and Reflection Designer installed at the same time? Or is there maybe an update to Lighting Designer that I need to download?
    Both were originally installed with Daz Connect. Reflection Designer is now installed through DIM.
    They should both work.  I thought we updated Lighting Designer at the same time to work with the new file.  If you reinstall Lighting Designer, do they both work?  If not, I will talk to Daz.
    Nope. As soon as I install Lighting Designer (this time via DIM), the Accept button is no longer accessible. I do have the other light panels that I saw in your video though. They weren't there before. But adding any of the lights does not make the accept button accessible like it is suppose to.
    Ok, it looks like I need to resubmit Lighting Designer.  I apologize for the inconvenience.
    Ok, it is submitted.  You should have an update early next week hopefully.
    Thanks!
