Help Log warning error + Duplicate
PandaAnonymous
I'm getting a duplicate error whenever I open a genesis 8 female figure, as I'm studying my log I realized that I get a warning error as soon as I open daz.
Here is the warning
2019-12-08 23:39:39.879 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudstorewgt.cpp(1054): undefined(0): TypeError: 'undefined' is not an object2019-12-08 23:39:40.526 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudstorewgt.cpp(1054): https://www.daz3d.com/skin/frontend/enterprise/daznew/groups/embeddable_scripts-918eab20546d8226ed168dc037883c8c.js(22): DazEmbeddable initializing2019-12-08 23:39:40.527 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudstorewgt.cpp(1054): https://www.daz3d.com/skin/frontend/enterprise/daznew/groups/embeddable_scripts-918eab20546d8226ed168dc037883c8c.js(38): v2019-12-08 23:39:40.527 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudstorewgt.cpp(1054): https://www.daz3d.com/skin/frontend/enterprise/daznew/groups/embeddable_scripts-918eab20546d8226ed168dc037883c8c.js(38): Found customer_id in URL: K6w3UECzhnBawVc5Nnqklp6FMRqW2pSFGz/k/1aP3gVWkbgnIuoFv0o2b2NiSLoNrsthYo94H5deV1d3l4cceElENV0TR/gqqA4RLGY5Qt0XiBYLQtOL17QkNheZInpk2019-12-08 23:39:40.922 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudstorewgt.cpp(1054): https://www.daz3d.com/skin/frontend/enterprise/daznew/groups/embeddable_scripts-918eab20546d8226ed168dc037883c8c.js(92): Checkout element not found, aborted2019-12-08 23:39:40.923 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudstorewgt.cpp(1054): https://www.daz3d.com/skin/frontend/enterprise/daznew/groups/embeddable_scripts-918eab20546d8226ed168dc037883c8c.js(22): DazEmbeddable loading2019-12-08 23:39:40.923 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudstorewgt.cpp(1054): https://www.daz3d.com/skin/frontend/enterprise/daznew/groups/embeddable_scripts-918eab20546d8226ed168dc037883c8c.js(35): querying for: /dazApi/category/tree2019-12-08 23:39:40.924 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudstorewgt.cpp(1054): https://www.daz3d.com/skin/frontend/enterprise/daznew/groups/embeddable_scripts-918eab20546d8226ed168dc037883c8c.js(35): querying for: /dazApi/category/compatibilitytree2019-12-08 23:39:40.925 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudstorewgt.cpp(1054): https://www.daz3d.com/skin/frontend/enterprise/daznew/groups/embeddable_scripts-918eab20546d8226ed168dc037883c8c.js(35): querying for: /dazApi/category/compatibilitymap2019-12-08 23:39:40.926 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudstorewgt.cpp(1054): https://www.daz3d.com/skin/frontend/enterprise/daznew/groups/embeddable_scripts-918eab20546d8226ed168dc037883c8c.js(35): querying for: /dazApi/category/map2019-12-08 23:39:42.507 WARNING: content-type missing in HTTP POST, defaulting to application/x-www-form-urlencoded. Use QNetworkRequest::setHeader() to fix this problem.2019-12-08 23:39:42.509 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudstorewgt.cpp(1054): https://www.daz3d.com/skin/frontend/enterprise/daznew/groups/embeddable_scripts-918eab20546d8226ed168dc037883c8c.js(35): resource fetched: /dazApi/category/tree2019-12-08 23:39:42.987 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudstorewgt.cpp(1054): https://www.daz3d.com/skin/frontend/enterprise/daznew/groups/embeddable_scripts-918eab20546d8226ed168dc037883c8c.js(35): resource fetched: /dazApi/category/compatibilitymap2019-12-08 23:39:42.988 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudstorewgt.cpp(1054): https://www.daz3d.com/skin/frontend/enterprise/daznew/groups/embeddable_scripts-918eab20546d8226ed168dc037883c8c.js(39): Unable to login with customer encrypted id2019-12-08 23:39:43.066 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudstorewgt.cpp(1054): https://www.daz3d.com/skin/frontend/enterprise/daznew/groups/embeddable_scripts-918eab20546d8226ed168dc037883c8c.js(35): resource fetched: /dazApi/category/map2019-12-08 23:39:43.153 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudstorewgt.cpp(1054): https://www.daz3d.com/skin/frontend/enterprise/daznew/groups/embeddable_scripts-918eab20546d8226ed168dc037883c8c.js(35): resource fetched: /dazApi/category/compatibilitytree
The error only happens to genesis 8 female figures, not any other genesis or genesis 8 male
Whenever I open a figure they all get duck lips and pointy noses
Duck lips and pointy nose are down to a character that has been saved with a non-zero default value, it has nothing to do with the log entries. I think there is a freebie known to do this - check the Currently Used list in the Parameters pane with the figure selected.
That's the issue I'm opening Victoria from product list not from a scene save or figure saved there shouldn't any save modifications and it only happens with genesis 8 females not the males or any other genesis figure
It's a vendor that messed up the creation of a file, or a maybe freebie maker if you grab those.
Yes, that's the way it works - if the morph is saved with a non-zero deault then it wil load non-zero in any file containing that base figure, unless the property has been explicitly set to zero in the file. You need to identify and either fix or remove the problem property.
