Wardrobe help
I would like to be able to place some clothing in a scene laying on the floor, as if someone placed them there. I've seen this in many other people's renders, but can't figure out how to do it. I have plenty of D-Force clothing but can't seem to understand how to simply drap it over a chair or lay it on the floor. Thanks for any help.
You have to click on the item you want to drap it on, then go to edit > object> geometry > add dforce modifier static surface, then it will collide. Put the item above the collision item, then simulate it, it should drop onto the collision item. Also, there is props made for it like https://www.daz3d.com/messy-laundry-mega-set and https://www.daz3d.com/laundry-day-mega-set
wow! thanks so much!
