what is this error? src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception
When I apply an Iray material that was bundled with the HanMei Hair color I get this error. I did a maual install, I am NOT using CMS:
2019-12-07 08:13:29.904 Invalid hierarchy for selected node(s) and "preset_hierarchical_material" type; no root(s) found.
2019-12-07 08:13:29.904 Error reading file, see log for more details.
2019-12-07 08:13:35.294 Iray [INFO] - IRT:RENDER ::   1.0   IRT    rend info : rendered frame 0009 in 5.450517s, 0.2fps (internal: 5.386535s, 0.2fps, overhead 1.2%)
2019-12-07 08:13:35.310 Iray [INFO] - IRT:RENDER ::   1.0   IRT    rend info : Scene graph manager init took 0.000s
2019-12-07 08:13:35.762 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in contentGetByRelativePathAndFilename: Unable to connect to the database
2019-12-07 08:13:35.871 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in CloudFIle::lookupFromDb: Unable to connect to the database
[...Dozens of this entry repeating]
2019-12-07 08:13:36.027 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in CloudFIle::lookupFromDb: Unable to connect to the database
2019-12-07 08:13:36.027 Invalid hierarchy for selected node(s) and "preset_hierarchical_material" type; no root(s) found.
2019-12-07 08:13:36.027 Error reading file, see log for more details.
2019-12-07 08:13:40.840 Iray [INFO] - IRT:RENDER ::   1.0   IRT    rend info : rendered frame 0010 in 5.539693s, 0.2fps (internal: 5.477026s, 0.2fps, overhead 1.1%)
2019-12-07 08:13:40.856 Iray [INFO] - IRT:RENDER ::   1.0   IRT    rend info : Scene graph manager init took 0.000s
  • TheKDTheKD Posts: 2,711
    Did you have the hair selected? When I have seen that error, it's because the vendor set it up so you have to have the figure(g8f g8m etc) selected to apply the texture. If I remember right anyways.
  • StratDragonStratDragon Posts: 3,290
    Thank you!
    No problem. I think most of us are so used to having to select the object and the surface to do it, they should ban this new method lol. But of coure I am biased, being one of those used to the old way.
    They should ban it, and that error message doesn't help. cheeky
  • aograiaograi Posts: 657
    I got this message in log when I tried to simulate wardrobe. Is there a reason for this outburst from my Daz? Keeps repeating
    2022-11-09 22:41:45.401 [WARNING] :: ..\..\..\src\dzopenclkernelfactory.cpp(32): Open CL notify: Unknown error executing clFlush on NVIDIA GeForce RTX 3060 (Device 0).
    2022-11-09 22:41:45.600 [WARNING] :: ..\..\..\src\dzopenclkernelfactory.cpp(32): Open CL notify: Unknown error executing clFlush on NVIDIA GeForce RTX 3060 (Device 0).
  • LeanaLeana Posts: 13,588
    Yes, the reason is a regression regarding OpenCL in the latest nvidia drivers. You need to go back to driver version 517 for now to use dForce. Nvidia is aware of the problem and working on it.
    Is this applicable also for RTX 3080? Funny thing is that I'm experiencing issues related to dzcloudtasknotifier.cpp only when trying to render 1 subject (https://www.daz3d.com/baryolax). For all other scenes with different subjects I never had any issues. Is it possible that the issue is the subject and not the graphic card?
    Cheers!
