Neighborhood Bar Renders...red?
AabacusAabacus Posts: 407
I picked up: https://www.daz3d.com/i13-neighborhood-bar-environment-with-poses on sale today. I loaded the defult set and now I get...this.
Other sets render fine.
I am...baffled. Nothing seems out of order...
Anyone else have thoughts? The iray in the viewer works fine.
2560 x 1440 - 7M
Post edited by Aabacus on
  • Check the emissives, the light bulbs, for their color and temp. Also let the render go a little longer next time. I'm not sure there is an issue except maybe some of the lights have a warmer temp or color.
  • NorthOf45NorthOf45 Posts: 5,898
    The scene loads some render settings, so check under Preferences->Scene: Render Settings. Make sure "Ignore When Opening a Scene File" is unchecked. Create a new scene, reset NVIDIA Iray render settings to default, then load the scene again. Set it to "Scene only" to remove any HDRI influence for now.
  • AabacusAabacus Posts: 407
    That fixed it but man that was a wonkey configuration. Thanks! If anyone cares 4.11 on a Mac. Mojave.
    edited November 2019
    <<dupe>>
