Retired
Catherine3678ab
Retired
Post edited by Catherine3678ab on
Catherine3678ab
Retired
nice work. A stagger pattern for blocks would be useful for walls.
nm
i would love to have a concrete floor that looked like an open spiral notebook.
truly.
j
retired
retired
Thank you so much...this is very cool
nm
first of all, thanks a lot! :D - one can never have enough concrete ^^
and thanks to this/you, i finally came around to dl the nvidia mats.. i always postponed it, but now i had a good reason, and great explanations about where to put what, it was so easy!
just one tiny little thing.. i put everything exactly as shown - i mean the nvidia mats installed themselves, but they are in documents etc - including the EAP folder. and your duf presets, same as usual in my library. but when i create a sphere/cube and pick a preset.. nothing happens. white. restarted DS, nuttin'. what am i doing wrong?
EDIT: actually.. now that those nvidia mats are installed, am i even supposed to see them all in my shaders, or do they need to be "called" by a preset/an application as you did right with this here?
retired
weird. i did select the surface in the tab, as usual for shaders.. do you think i'd need to "refresh" my nvidia components or whatever by switching my laptop off/on?
EDIT: well restart at least didn't help a bit.
EDIT 2: eureka! now it works - all i had to do was to add the documents/mdl path in the shader mixer pane! i found this in the readme from MCDlabs "vMaterials 1.5 AEC IRay Shaders" from sharecg. i had bookmarked their awesome freebie months (years?) ago, but only downloaded it today since i finally got the nvidia requested materials... and it was written there,
"You need to open the "Shader Mixer" Pane.
In that pane click on Edit > MDL Directory Manager
select "Base Paths" and then "ADD" a Directory.
Select the directory above. click "Accept"
NOTE: These will NOT work if you do not add the additional mdl directory. The mdl files included in DAZStudio are diferent than these ones, These are maintained by NVidea and abide by thier standards."
retired
you're very welcome, that's the least i could do ^^ - hope it might help someone :)
