Scene will Not Render
I have a scene that just seems to get stuck at "Compliling shaders" 0/1 and doesn't go any father.
It's strange because pushinng render Problems.
Doing Iray preview? No problems.
CPU Render.
Post edited by Psyckosama on
CPU Render.
Does the log file says which shader that is the culprit?
That might help narrowing down the problem.
No errors in the log files...
I've had this with high SubD set on something in the scene.
cranked down subdiv
no luck
In the Surface setting there is sub-d level for displacement so give that a check.
