Can you only apply Aureska's head and body, and not her face?
FlortaleFlortale Posts: 611
edited November 2019 in The Commons
Is it possible to not apply her face morph, but apply everything else; body and head?
https://www.daz3d.com/aureska-hol-hd-for-zelara-8
Same thing with this model, can you not apply her face?
https://www.daz3d.com/hell-princess-hd-for-genesis-8-female
https://www.daz3d.com/gargoyle-for-genesis-8-male - Same with this Gargoyle, can I leave out his head/face morph, to keep him looking human?
Post edited by Flortale on
  • Matt_CastleMatt_Castle Posts: 3,251
    Hell Princess is a full body, single slider morph. I don't have Aureska, but as she's by the same PA and has similar notes in her description, I presume she's the same. And RawArt's figures are also always full body (or, if there are any, they're an exception to the rule).
    It is however possible to create an inverse morph (in something like Blender) that can negate the SD portion of the morph, but some of the HD detail will remain.
    Still, it works quite well; I've done it for things like RawArt's centaurs so that I can keep the body shape, but use a different head morph. It won't absolutely resemble the replacement head, but as with a lot of these figures you're largely committed to using the original textures to keep the overall effect, they were never going to be perfect dopplegangers.
    Post edited by Matt_Castle on
    You could try this product https://www.daz3d.com/shape-splitter
    i have used it a few times on products with just a full body morph and it worked fine.
  • FlortaleFlortale Posts: 611
    Thanks, looks good!
    Heads and faces aren't separate. Bodies and heads are, most of the time. You can change facial characteristics with various add-on products, but I think you are unlikely to drastically change Aureska's face given the drastic, stromg modeling.
    Post edited by fastbike1 on
  • Oso3DOso3D Posts: 15,116
    I'll point out that you can still dial in other heads/faces and probably get interesting results, though; those faces are all really humanlike.
