Code 66/Multi Map Loader/Failed to load script
Hello, the script can not open.sad
My .obj is placed in the scene, it is selected but when I click on the Multi Map Loader script, I have the following message: "Failed to load script"
The log indicates : "Failed to load script: /Users/admin/DAZ Library/Scripts/Code 66/Multi Map Loader/Multi Map Loader.dse"
I checked my way, everything seems to be set up correctly.
I specify that I am on MAC Os..Maybe this script only works on PC?
Can you help me ?
Patrick
  • WojtkoWojtko Posts: 82
    I confirm..I tested it on a PC and the script works.
    Maybe it would be wise (unless I'm mistaken) to say that the script does not work on MAC OS!
  • LeanaLeana Posts: 12,987
    edited November 2019
    Which version of MacOS is it, and which version of DS?
    Also, how did you install the product?
    (For the record, the PA is a Mac user, so it’s most definitely supposed to work)
    Post edited by Leana on
  • TotteTotte Posts: 14,922
    Hi,
    The script is developed on Mac OS X (was then tested on Windows), so if it doesn't work, something else is the problem.
    I just tested the release and DIM downloaded version, it works. Which version of OS X are you running? Tested on 10.13.6 and 10.14.6.
    If you are running 10.15 that will be the issue...
    Post edited by Totte on
    And which version of DS are you running (minimum version is 4.11.0.383 )
    MAC 10.7.5
    I just checked everything. The path and the locations are good ... I think my MAC OS X is too old because on the PC this script works.
    I am on the latest version DAZ.
    Merci
    Patrick
    Merci
    Patrick
    Which version of Mac OS X?  Ah, 10.7.5, hmm, I would recommend jumping off 10.7 and 10.8 and at least step to 10.9. (10.7 and 10.8 are some of the worst Apple has done)
    The script doesn't do anything that does not go through the Script APIs, but only thing I can think now is if the path name contains rally weird characters like ç (that someone had in a product  name that didn't work.
    But as 10.7.5 is old it can be that things the script does through the OS is not possible to do in 10.7.5
    It's planned in my future Christmas presents; a new Mac !!! LoL!
    No, there are no special characters and the path is good.
    In addition, I installed it on my PC and it works.
    We'll see if the new Mac (I'm writing to Santa Claus right now) will make it work.
    Merci
    Patrick
