Object collision possible?
Hi, is it possible to create object collision?
That I can set the ground of a room to... the gorund? that the mody will not fly through it? (unless I remove the connection).
I created a box and did try to pose a man on it, but he just fly through it :(
Also how will it work if I use objects like, a hand on the Door? that if I move the hand the door is moving too, or using a Pistol in the hand, can I stick a pistol in it? (just an example)
I did not find a button for connections.
Thanks!
Update, I tested it with adding the box/cube as parent to the body, but that cause, that the body will morph complete crazy O_O
before:
After parenting:
that loks kinda unhealthy! But hey.... now I can move both around :/
Post edited by Loony on
I don't understand what you did to get the second image from the first.
I did what someone said, parent it to the sticky wanted object.
So I clicked the box (podest) and selected "set parent" (or something) and selected the man (viewer) and... this did happen...
I did try to reproduce it, but I had no success... NOW it works O_o
