Invisible Character?
DPWDPW Posts: 267
Hi,
I have a suggestion for an invisible character if anyone is interested.
Is it possible to have a character like Genesis, that does everything that Genesis does - only they don't appear when rendered. Their movements do along with any clothing or armour they're wearing, but the actual character doesn't. Like the invisible man.
Would this be possible to do?
Thanks,
Dean
    Simply use genesis, pose him then before you render, hide him. Use the Scene tab to do this; there should be an eye next to the character, click it to hide it.
  • DPWDPW Posts: 267
    Oh right,
    Thank you! I'll give it a go.
    Cheers.
  • ben98120000ben98120000 Posts: 469
    Or in parameters tab, display menu, turn off Visible in Render.
  • JaderailJaderail Posts: 0
    edited January 2014
    Or if you want SHADOWS from the invisible figure use Uber Surface Shader and set Fantom to on for all the figure. It is gone but still casts a shadow, also another cool effect.
    Post edited by Jaderail on
  • CybersoxCybersox Posts: 9,913
    Here's an "invisible" girl I did for a render contest here a while back.
    2000 x 1333 - 628K
  • namffuaknamffuak Posts: 4,513
    If you want the figure to show but not really show, dial the opacity down to something like 15% in the surfaces tab.
  • Ryuu@AMcCFRyuu@AMcCF Posts: 806
    And and if you want something a bit more like the "Predator"-like or Romulan cloaking effects, don't forget to play a bit with the Refraction.
