Refresh DAZ database(??)
I'm not sure of the proper wording, but I completely rebuilt my PC so I have all SSD's. Before the rebuild I had installed all the DAZ files on a 2T SSD.
Once the system was stable I installed a new dim on my C drive. Looking at "Smart Content", everything came up OK, but are showing as black and while icons that require installing (using the Right Click option), before working. The "Content Library" is all color. My newly purchased stuff is coming up in color in Smart Content".
Since I know DAZ worked perfectly before the rebuild, isn't there a process available that will refresh the database
318 x 525 - 127K
There is a transfer script that does the whole process. I'm not sure if there is a way to fix it now that you've partially done it. Depending on the size of your asset library you could delete everything and let DIM install it all again.
Did you copy over you manifest files as well as the content? Those are essentially files that tells Daz what is installed.
