dForce fur
i would like to know how to export an animal say AM Felidae w/dForce fur as obj to use in vue
  • LeanaLeana Posts: 12,902
    AFAIK you need to enable “preview PR hair” in the parameters of the hair first if you want to export it.
  • yes did that for all fur but when loaed in vue no fur still :(
  • scorpioscorpio Posts: 8,533
    I think you will need to export it as an obj
  • felisfelis Posts: 6,053
    I jusr tried in blender - showed up fine.
  • exported as obj from daz w/in simulation tab  preview PR hair on for all fur mane etc opened in vue no fur
    I dont use blender so any other ideas as to why it doesnt expot for vue please
    I assume you mean the parameter tab.
    I just used strand-based-hair to test, and to my knowledge dForce hair is in terms of geometry identical.
    And I can't see any reason why vue would read an obj differently.
  • so you all have had animal fur dforce export as obj and not me :)
    does anyone know of more deatails to kind me
    please
    I do not know, why it doesn't work for you.
    If you look at your animal in the viewport, texture shaded, can you then see the hair (not as the actual hair, but as a simplified version)?
  • the LAMH fur w/animal exports as obj but so far not the dforce
    But can you see the hair in the viewport before you export?
  • yes dforce  fur is there and renders awesome in daz
    Have you tried exporting something else with hair?
    Like a simple plane with strandbased hiar
  • all LAMH animals w/fur export as obj to vue
    exported to blender no fur can u help me please ty
    I noticed that in the obj export options, there is a 'Polyline' - that must be checked.
    Beside that.
    I do not have the animals you do, and I do not know if there might be differences among products, why I suggested using a primitive for test.
    For a more controlled test I start with an empty scene.
    dForce hair product
    1) Load object (here Femme Fatale hair)
    2) Select dforce hair part
    3) Check Parameters > Line Tesselation (for viewport)
    4) Export as obj
    5) Import
    And for a primitive
    1) Create primitive
    2) Create strandbased hair
    [3) Paint hair]
    4) Parameter > Line Tesselation > 'Preview PR hair' > ON
    5) Export as obj
    6) Import
    Both loading as expected.
  • GoggerGogger Posts: 2,507
    Hmm.. it has been a while since I messed around with VUE, but it vaguely seems like there was some goofy thing where POSER/DAZ things would import to VUE with Transparency inverted - in other words, things were invisible until you corrected the Transparency setting in VUE.  Maybe?
  • have no problem exporting LAMH to vue as obj I just cant get SBH dforce hair to export
  • edited October 2019
    Beside that.
    dForce hair product
    4) Export as obj
    5) Import
    And for a primitive
    1) Create primitive
    [3) Paint hair]
    5) Export as obj
    6) Import
     but not exporting as obj to vue
    Post edited by tinkstar_8a2fb05047 on
  • Parameter > Line Tesselation > 'Preview PR hair' > ON?
    1600 x 900 - 327K
    And how does the menu look under Simulation > Hair > Pre Render
    do not know where you are directing sorry
    1600 x 900 - 263K
    IN the picture you attached, around 2/3 down you have a parameter "Preview PR hairs"
    It is set to Off, but shall be On
  • no fur in vue when exported and I need to thank u for all this effort
  • save as obj preview hair on,viewport tess=1 render line tess=2 no fur when exported/ imported to vue..but yes have dforce fur when when loaded/imported into daz
    can we start calling it Dfur?
