Bug or feature?
I don't know if this change is intended in the new DS version or not, but DS 4.12 deletes blanks at the end of name of the render.
I always put a blank at the end of the name for improved readability. (It also makes it easier if I want to change the name of the image).
I would like to have the ability to put space at the end of a name, back.
(Or if there is som knob or switch somewhere I can adjust myself).
  • I'm on a mac using DS 4.12. I saved a scene as Test(space). The file appeared in my files as Test .duf.
    Is that what you meant?
  • reserv888reserv888 Posts: 1,164
    edited September 2019
    Exactly. But that is not how it works for me anymore.
    (PC Windows 7).
    Post edited by reserv888 on
  • Hopefully someone with a Windows machine can test for you. You may need to contact customer service depending on whether anyone else can come up with a suitable solution or verify your finding.
    Ok, Cris. Thank you!
    I am told
    The change is intentional. Leading and trailing whitespace are trimmed. Consecutive whitespace is simplified. Each of these are possible/allowed while editing, but are cleaned up when the text field loses focus or when enter/return is pressed.
    Post edited by Chohole on
    Thanks a lot Chohole!
