About saving morphs? - Solved.
Catherine3678abCatherine3678ab Posts: 8,556
edited September 2019 in Daz Studio Discussion
Okay, normally I just save my little morphs to my own folder under Morphs and all is well but today I tried in 4.12 to save a morph to the Actors, real people ... where all the products have been putting head morphs. All seemed to be in good order until I went to save the morph. Right placing or wrong, this is the first time the new morph did not appear in the drop down list to be selectable for saving! Why?
Post edited by Catherine3678ab on
  • Are you sure you hadn't already saved it? Is it still working?
    No I hadn't already saved it, I had just made it and assigned it to Actors/People [where for some reason the PAs have been putting heads] ... and it simply was not on the option list of files to save. So I went back and changed its position on the Parameters Tab back to my own folder under Morphs/Catherine3678a ... and then the option appeared and I could save it. Am wondering if there was a different 'type' of morph that it needed to be called in order to be under People/etc?
    I tried to replicate what happened ... aaahhhh ... I figured it out, going blind here with all this tiny type ... misfiled it! Thank you.
    .... and I discovered how to set the screen resolution lower so now D/S's sliders are easier to see :-)
