Zero Morph's part
Dieggo Masamune
Hello everyone, i have a question.
I created a morph for Genesis 3 Female and the morph changes completely her body, head and etc.
There's a way i can "zero" only her head and keep the body i created ?
There are several. Do you want an abrupt switch, or do you need a gradual switch (in the neck probably) to avoid a nasty jump?
Hi Richard! Thanks for the answer! Oh i want a abrupt so i can model a new head :D
That's fairly simple then:
(from memory, sonme commands may not be quite right but you should eb able to translate)
That worked!! Thank you sooooo much!!!!
restore base shape of the loaded character is CTRL+ E
with CTRL+ E the shapes always back to "default"
you can change the "default" shapes by using the "MEMORISE SHAPES"
with CTRL + E you restore the shapes to the memorised shapes
Oh that's very helpful too, thanks!!!
