Multi Man error (Solved)
GalaxyGalaxy Posts: 562
edited September 2019 in The Commons
How to use this product https://www.daz3d.com/multi-man-for-genesis-3-male
I am getting this error. Any solution?
1914 x 1031 - 109K
Post edited by Galaxy on
  • Try opening it, not using smart content, it may work better !
    Load G3M first then try.
  • GalaxyGalaxy Posts: 562
    I tried to load G3M first. Not working.
    Tried content library as suggested. Not working.
    1920 x 1044 - 122K
    1920 x 1037 - 127K
  • GordigGordig Posts: 10,865
    How did you install the product? Multi Man is one of those products that didn’t work for me when installed through Connect, and had to be installed through DIM. To my knowledge, this only happened after the name was changed from Morpheus, although it’s possible that that’s a coincidence.
  • The lack of thumbnail in the Smart Content pane suggests soemthing is wrong with the isntallation, certainly. It should n't matter but try unisntalling (right-click on the Product) and then installing through DIM - if that does work try reinstalling the Connect version and if that still fails open a Technical Support ticket.
    I tried Connect. It installed correctly and color version of icon appeared but refused to load.
    Then I tried DIM. It installed without any error but refused to load.
  • I just installed via Connect and it looks as if no files are decypting for me either (checking the log file it's complaining that it can't find the opening bracket, and the PNGs are unreadable). So yes, this looks like a bug report please.
    "try unisntalling (right-click on the Product) and then installing through DIM"
    Now it is working.
