Static Variable for a Function?
Hi,
I understand it's possible to create static variables in Javascript.  Because functions are considered to be objects, it's possible to have something like this:
(function() {  function doSomething(param) {    if (doSomething.x == undefined)      doSomething.x = 1;  // this value is retained between calls  };  doSomething.x = undefined;  })()
Now, I'm trying to setup my own library of functions, and I'm told that it's best to define them in a separate namespace instead of putting them in the global namespace.
So for the above example, I'm doing the following (which uses Javascript's 'other' syntax where you define first the property and then the value):
var MyLibrary = {  stuff : true,    stuff2 : "hello",    doSomething : function(param) {    if (doSomething.x == undefined) {      doSomething.x = 1;  // this value is retained between calls    }  },	    doSomething.x : undefined  // this doesn't work - why??};
The trouble with this 'other' syntax is I can't figure out how to declare the static variable.  Does anyone know how?
  • andya_b341b7c5f5andya_b341b7c5f5 Posts: 694
    edited August 2019
    The variable doSomething.x isn't accessible until you have finished defining the object MyLibrary.  This works:
    var MyLibrary = {  stuff : true,    stuff2 : "hello",    doSomething : function(param) {  	var z = 'bar';    if (MyLibrary.doSomething.x == undefined) {      MyLibrary.doSomething.x = 1;  // this value is retained between calls    }    MyLibrary.doSomething.y = 'foo';  },    //doSomething.x = undefined  // this doesn't work - why?? - doesn't exist  //MyLibrary.doSomething.x = undefined  // this doesn't work either, same reason  };// Function variables undefined before you call the functionf = MyLibrary.doSomethingprint(f.x);  // undefinedprint(f.y);  // undefinedprint(f.z);  // undefinedf();print(f.x, f.y);  // 1 fooprint(f.z);      // undefined - local to function
    Post edited by andya_b341b7c5f5 on
  • Stretch65Stretch65 Posts: 176
    Thanks.  Javascript isn't exactly my favourite language :)
    Not mine eiither!  I'm baffled by it's popularity outside of web browsers.
  • TotteTotte Posts: 15,380
    ECMAscript do have some percuilar things,my favourite traps is still
    function stupid(a,b) {
    c=a+b;
    printf(c);
    a = 1;
    b = someObjectArray[someindex].somemember;
    stupid(a,b);
    result >> 11
    c=a+b;
    printf(c);
    a = 1;
    stupid(a,b);
    result >> 11
    Really?  Lol .. Now I hate this language even more.
