Geometry Shell Visibility
Is there a quick way to turn all of the surfaces off? I just want one to be visible and it's a pain to click on each one individually. tx
  • scorpioscorpio Posts: 8,534
    Select all the surfaces turn the opacity to 0 in the surfaces tab then turn the one you want to 100 or whatever you want it at.
  • HavosHavos Posts: 5,707
    Another way which switches the surfaces off is to click on the Parameters pane with the Geo shell selected. Go to Shell->Visibility->Surfaces
    Now switch to Edit Mode (Right click on one of the surfaces), now select all except the one you want to remain visible, right click again. Set->Value(s).
    A pop up will appear, click on "ON" and it will change to "OFF"
    Now all except one should be OFF. Right click again to leave Edit Mode.
  • LinwellyLinwelly Posts: 6,070
    edited August 2019
    This will give you gloss artifacts and similar stuff, it's better to turn off the shell visibility in the parameters as Havos explained
    Post edited by Linwelly on
  • Thanks!
