Morph problem.
Hi
I'm looking for some help with transfering some unique morphs in Daz. I try to follow instructions from the forum and from some youtube tutorials but I always get this error ''Geometry did not match, failed to create morph''. It seems not only do I get this error with custom objects and models but also with daz figures.
PS: I had been searching for tutorials on google but I  didn't find anything useful. I've decided to ask for help here. I'm a begginer trying to learn how to transfer morphs into daz.
  • Which figure? Was the mesh exported at base resolution? If it is Genesis 8, or using add-ons/grafts, had you removed things like the lashes and brows?
    I want to transfer some unique morphs from a custom character that isn't a daz model into daz on a genesis 8 male. I tested on Eva 7 to try to change her apparance and that works fine but I'm interested on a custom character to bring it's morphs into daz but when I do this I get this error'' Geometry did not match, failed to create morph.
    I already removed accesories, eyebrows, eyelashes and set the genesis 8 male to base resolution  but it doesn't work.
  • LeanaLeana Posts: 13,787
    I’m not sure which tutorials you’ve been watching, but you  can’t create a morph directly from a totally unrelated mesh, a morph is created from a version of the same mesh where vertices have been moved.
    You might be able to project the shape on the target figure using a variation of the methods used to transfer morphs between the various generations of Genesis figures, but there’s no guarantee the results would be good.
  • azazelsteiner6azazelsteiner6 Posts: 70
    edited September 2019
    Thanks. I'd like to try but how can I do this?
    Post edited by azazelsteiner6 on
