content manager
photostar73photostar73 Posts: 0
Hi all,
I'm new to Daz Studio4.6, and I would like to know if there's a way to avoid to get a empty hd very soon with daz content.
There's a way to choose where to install content (external hd for example), and have the program and content manager work properly?
There are any tutorials about this?
Thank you very much in advance for the help!!
  • Richard HaseltineRichard Haseltine Posts: 112,009
    Just set the folder you want to use as the target for the DAZ Install Manager, assuming you are using that, by clicking the gear at top-right to get preferences, going to the Installation tab, clicking the + button at lower-left then using the ... button to add your folder. If you check the Show details box before installing with DIM you will be able to check that the right folder is selected, and to change it if not. In DAZ Studio open the Content Library pane (Window>Panes (tabs)>Content Library) and in turn right-click on DAZ Studio Formats, Poser Formats and Other Import Formats, in each case choosing the Add directory option and selecting the same folder as you chose in DIM.
  • photostar73photostar73 Posts: 0
    thank you so much! your answer has been very useful and clear: thank you so much again.
    Now my content manager gets everything eithr from the C disk and the D disk without giving any other instruction, and the install manager puts all the new material on the new D disk.
