Smoothing modifier script?
Is there a way to include "add smoothing modifier" to the scripts menu? Is there ANY way to get to it without going through edit > object > geometry > add smoothing modifier?
  • algovincianalgovincian Posts: 2,724
    edited August 2019
    Right click on the script from the Content Library and choose Create Custom Action.
    Another option is Window -> Workspace -> Customize
    Then set a hotkey:
    Hope this helps.
    - Greg
    616 x 638 - 146K
    Post edited by algovincian on
  • mr clammr clam Posts: 707
    edited August 2019
    Thanks, Greg. Those look like pretty good solutions, but I'm having trouble implementing them. I can't find "add smoothing modifier" in my content library and when I try to customize the workspace, the option doesn't appear as shown in your example. Any ideas? Am I missing these options because I'm still using Daz 4.10?
    171 x 98 - 19K
    Post edited by mr clam on
    I'm running 4.11.0.383 release, but it's not like the smoothing modifier is a new tool. Maybe it's just hiding under a different category in 4.10?
    - Greg
  • TheKDTheKD Posts: 2,711
    Just checked, it isn't anywhere on the left side in my 4.10.123 either. The only place I found it is on the right side, menu tab > main menu > object > geometry
    I guess that's another reason to upgrade.Thanks for checking!
