Apply materials option missing?
sydgrl3dsydgrl3d Posts: 32
I may be missing it somewhere, but I could have sworn that at one time or another, if you hold down "command" or "option" or "Control" while clicking and loading a texture, there used to be a 2 option pop up that asked if I wanted to "ignore loading texture maps" and continue to load all the other shader options or something to that effect.
Has that option been removed or moved to a different location in 4.6?
Thanks
    It's still there, and I use it regularly. I assume it's not working for you though, so details on how you're trying to apply the texture might help, and what version you're running.
  • sydgrl3dsydgrl3d Posts: 32
    Im running 4.6
    I want to load a characters materials without loading the actual textures, as that will overwrite the current textures on v4.
  • Richard HaseltineRichard Haseltine Posts: 112,305
    The ctrl/cmd key works only with native presets - if you have only Poser mat files it won't do anything.
