why does this happen when posing
What am i doing wrong for this to happen
425 x 865 - 55K
  • Do you have https://www.daz3d.com/big-girl-morphs-for-genesis-8-female installed? It did have an issue with a corrective morph that kicked in when it wasn't needed, though if it's been there for a while it may be worth checking for an update. In any event, if you go to the parameters pane, enable Show Hidden Parametrs in the option menu (the lined button in the top corner, or right-click the tab) and look under Currently Used you should be able to find and zero the problem morph (it's likely to be hidden as it should be a background helper that kicks in only when needed).
  • westcalawestcala Posts: 30
    edited August 2019
    Thanks richard uninstalled big girl morphs and that did the trick thanks for the information.
