Last Render
Steel Rat
hello All,
How do I view the last render? I've been clicking all over the interface, menus, pull downs, pop-outs, and can't find a way. I don't use the render library, I save to a specific set of folders. So when I accidentally close the render window, the only way I can see a previous render is in the Render Editor, which doesn't allow me to bring the render window back up, only shows me a thumbnail. I can at least save the render from there by right-clicking on it, but ideally I want to bring the render window up again.
Also, is there a better way to save renders? I find the existing way very clunky and unintuitive. I'd much prefer the old tried and true method of clicking a save button and a save dialog pops up.
Thanks!
File>Save Last Render will also work. There isn't a way to reopen the render window (in the case of iray at least closing it told DS to clear the data that had been sent to Iray/the GPU). It does exist as %appData%/Daz 3D/Studio4/Temp/Render/r.png, so you could fairly easily use a script to hae the OS show it.
