background enterface changed
The silliest things happen to me
I've load an old prop and Sudnly I had a white colour background enterface instead of the usual blue or black ( pic attached )
and since that day I couldn't reitrve it , the white  color heart my eyes and I can't foucous when I use daz
Is there Any way to retrive or change the background coulor..?
1920 x 1080 - 331K
  • carrie58carrie58 Posts: 4,183
    Go to "Windows /Tabs /Background " click on that and then change the color to something more comfortable
  • Actuallty if it's persisting it's more likely Window>Style>Customise Style, then change the background colour under 6 Viewports
  • TaozTaoz Posts: 10,401
    edited August 2019
    I think you mean "Environment" tab, then select "Backdrop" from the "Type" Combo Box. But like Richard says, it only changes the color temporarily (for that particular scene).
    Post edited by Taoz on
    oops I was close ......thank you Taoz and Richard
  • L'AdairL'Adair Posts: 9,479
    edited August 2019
    To expand on this: There are a number of older products that, for whatever reason, change the background color of the viewport. To change it back, or to put in your own preferred color, you need to Customize the Style.
    Customize Ds Viewport Background
    @ahmed1hse, This image shows both the menu items to reach the dialog window, and the dialog window with the Viewports section selected. Normally, the menu will collapse when the dialog opens.
    If you haven't changed any of the color options, you can click on the Defaults button and the viewport will revert to the original color without affecting other colors.
    I hope this helps.
    Post edited by L'Adair on
  • Thank you so much for all of your help
    I hope this helps.
    @L'Adair - Thanks a lot, Yes I retrieve it to the very old one
    The grey color -which is the default- is very smooth and easy to the eyes
