Adding a Specular Map
Hello All,
In Poser, I can easily add a 2D specular map to a material, so that the specular value only covers the area of the map, instead of the whole material.
I'm not seeing a way to do that in Surfaces in DS, or I'm just dense.
I've viewed the surfaces videos on YouTube, but none of them dealt with a similar thing, or I didn't find the right one.
Any ideas?
  • VisuimagVisuimag Posts: 578
    edited August 2019
    I'm assuming you're using Iray. If so, add the specular map to Glossy Layered Weight and Top Coat Weight.
    Post edited by Visuimag on
    ...and for 3Delight it would go into specular strength.
  • Steel RatSteel Rat Posts: 417
    I'm using Iray, yes.
    If there's already an image attached to those two values, can I add another image in top of it, to complement it? I don't see a way to add another Top Coat Weight...
