Dforce animation.
Hello all,
Need help again.. sorry.
I'm trying to do a animation togheter with dforce.
It's a man laying in bed with a blanket on him.
I want the blanket to "move" togheter with the man.
So i place the blanket over the man and choose simulate current frame (0).
It's looking fine.
Problem is when i try to simulate the hole animation, the blanket "pop" up in the air
again and falls down over the man during simulation. First on frame 10 the blanket looks like frame 0 when i simulate curent frame.
I want to start dforce simulation from the simulated blanket in frame 0.
I've tried diffrent setting for the blanket - like start from shape off frame 0.
Anyone? Sorry if this has been answered, couldn't find an answer.
  • Richard HaseltineRichard Haseltine Posts: 112,126
    Use the Initialisation Time in Simulation Settings to let the blanket drape into place - for soemthing like this you probably want to use a play range simulation, so that you can add intermediate steps to the sitting up pose.
  • Thanks for the answer, i will try tomorrow after work.
    Play range? What’s that?
    BR // Daniel
    Play Range is one of the options in Simulation Settings (I think I'm remembering the label right) - use the Timeline isntead of doing a single frame from memorised pose to final pose.
  • ”Use the Initialisation Time in Simulation Settings to let the blanket drape into place ”
    Thanks, worked perfectly.
    BR // Daniel
