Is It Possible To Slave A Surfaces Slider To A Parameters Slider ?
3dcheapskate
Specifically I want to create a couple of integer sliders on the Parameters tab that control (via a simple float multiplication factor) the Tiling > Horizontal/Vertical Offset sliders on the Surfaces tab.
Is this possible ?
Note to self: Creating a new integer slider is quite straightforward, and covered here - https://www.daz3d.com/forums/discussion/286676/ds-creating-a-slider-on-the-parameters-tab-that-can-only-have-integer-values
Yes, as I said in your other thread it has to be done via script.
Thanks Richard. I'll continue this over there.
