Saving Daz Studio not on Drive C?
Hello,
althought I told Daz to be not on C it does load all the stuff i downloaded on C...together with the my library stuff and all the saves.
And you know...C is usually the place with the less free room capacity left. Is there any way to change this to an other drive? Did i miss some instaling options there?
Best regards,
Mika
Post edited by Chohole on
  • macleanmaclean Posts: 2,438
    During the initial install of DAZ Studio, you should see separate options to install the program and the content. For example, I have the program on C and my content on E.
    I'm not sure if you'd have to uninstall and re-install everything. You could just try running the installer again and choosing a different location for content. That shouldn't change your UI or other settings. You may also have to look at the DIM settings if you're using it to install content. (I install everything manually, so I'm not sure).
  • Thank you  i will tacke a look for that install options.
  • chris-2599934chris-2599934 Posts: 1,925
    I recently moved my Daz content to a different drive (leaving the program installed on C:). It was very easy. There's a thread about it here:
    https://www.daz3d.com/forums/discussion/332926/moving-daz-assets-from-one-drive-to-another
  • yep  it worked.
    was a little bit tricky with changing the smart content
    but now i have my C drive with a lot of free gigs again :D
    Good deal!
