Bryce 7 Pro aspect ratio ??[SOLVED]
ed3D
_and to have particular bryce 7 pro aspect ratio ??
+16 : 9+
seems to have some trouble about it _
Post edited by ed3D on
ed3D
+16 : 9+
ed3D - not sure what you mean. File > Document Setup (or Ctrl+Alt+N) lets you set any document aspect ratio. Untick Constrain Proportions and enter in the Document Resolution fields the width x height in pixels. Or enter the Document Aspect Ratio width : height. If you enable Constrain Proportions you can then set either the width or height in the field and the other one is calculated according to the aspect ratio entered.
Horo: +alright then _ Thanks kindly +
_did come up with An Solution since , asking this Question +Was shooting for 3840×2160 (4K)
ed3D - So it helped. Thank you for reporting back.
+ don't know what the trouble was _ after Your remark , went tryed again And came out right
solution was To crop , cause wide was right and height was over , Like 'about 2300 or some such
_thanx again +
