Transfer Utility
Hello.
Does enybody know how to transfer G8F partly? For example, only to top part of dress (I don't want transfer anything to the skirt).
Thanks.
  • Matt_CastleMatt_Castle Posts: 3,312
    I don't believe you can do a partial transfer with the transfer utility (although I'm prepared to be corrected on that), but my main question is "What are you trying to do, and why do you not want to transfer to the skirt?"
    Is this something that is already weightmapped where you want to keep existing rigging (in which case there may be a better solution than using the transfer utility to transfer weights), or is it something you've got unrigged but you want to dForce the skirt?
  • Victor_BVictor_B Posts: 392
    edited June 2019
    Ok, I think I found a solution: I just deleted all unnecessary bones after transfer.
    it's simple as potato. ;)
    Post edited by Victor_B on
    You may find that having unweighted areas will cause problems (it certainly can in other programs, I've never tested it in Daz), so I suggest that any left-over vertices should be weighted to the pelvis, even if you don't want it to have any weighting to the legs.
