Centurion XIV for G2M converting to G8M using Riversoft Art's clothing converter
Ran the clothing converter twice, both times the left footwear worked fine but the right had a blond look to it. The rest of the armor had proper color. Looked through Surfaces in the Daz3D app but saw no apparent differences. Has anyone seen something similar?
  • The Texture Shading in Daz3D looks proper. Change the view in the app to Iray the right sandals goes blond.
  • MelanieLMelanieL Posts: 7,867
    I've seen this problem before - try this thread: https://www.daz3d.com/forums/discussion/134201/centurion-sandals-not-equal
  • It works fine.
    Though I cannot save the fixed image setting to the boots in the Content Library. Does this mean every time I load the boots on another character I will have to reset the right boot?
    edited June 2019
    Probably true. Maybe if you have a suitable image editor (Photoshop or whatever) you could change the gamma setting and resave the texture file? (But then if the product is updated for any reason it would overwrite again.)
    ETA: Actually thinking about it more, you should be able to save as a material preset for the boots, which will save your Iray material settings so you can apply them next time you want to use the boots.
    Post edited by MelanieL on
  • True. Still a noob in Daz, but will look into that. Thanx. wink
