Aiko 4 missing
For some reason Aiko 4 isn't in the figure line up. The downloader shows she is installed but can't find her. V4 and the Girl are shown but not A4.
Anyone else had this happen? What, if anything to correct the problem.
  • y3kmany3kman Posts: 900
    Load Victoria 4 and go to her morphs (either from the Parameter or Shaping tab). Aiko 4 should be there. Dial it to 1.
  • SixDsSixDs Posts: 2,384
    Only if the Powerloader is set to load A4 when Victoria 4 is loaded, y3kman.
    I can't help you with Smart Content, if that is where you are looking for A4, Imposer12, but if you look under the Content Library tab you can find it here:
    Poser Formats > "your content library" > Figures > DAZ People > Aiko 4, if you want to load a new V4 with A4 already applied, or
    Poser Formats > "your content library" > Pose > DAZ's Victoria 4 > Morph Injections > Aiko 4, if you want to add A4 to an already loaded V4 (you would then follow y3kman's instructions) Note: Unlike the Genesis series, V4 requires that that the Head be selected to access the head morph slider, rather than the root node.
