Need help with choosing a graphics card
Daz uses cuda cores for rendering,yes? I resently got my first job and have been looking at affordable graphic cards purely for rendering. I have been trying to find one around $200-$250 or less that will be viable for rendering. Right now I am rendering using CPU and even the viewport for iray takes forever before i can see properly. So I need advice on which card would be cost effective and be somewhat better than cpu rendering.any tips or advice are welcome! Also sorry if this is in the wrong place
  • Richard HaseltineRichard Haseltine Posts: 111,336
    You want enough memory to hold your typical scenes, at least, otherwise the speed will be irrelevant. How much content do you have in most of your scenes?
  • LenioTGLenioTG Posts: 2,118
    The benchmarks here are pretty comparable to Iray performances: https://www.cgdirector.com/octanebench-benchmark-results/
    I'd spend a little more and get a 2060 if possible, since it has tensor cores and a future update of Iray will probably use them, with a noticeable performance increase.
    Otherwise, GTX 1660 and 1660 Ti are pretty nice cards.
    You could also find a used 1080 if your PSU can handle it.
    The 1080 has more VRAM, the others have 6Gb...that is double what I've used until now xD
  • memoriivmemoriiv Posts: 64
    I just need one good enough to be speedy in previews iray really. I am working on a visual novel and we will be rendering on a render service so that I might set the next scene up as the previous one renders. CPU only previewing is not great
    The memory requirement is still much the same.
    I suppose 4-8 gb would be good at the moment
