Need help making elevator doors open at the same time going separate ways left and right
Hi guy's, I'm doing scene and I need elevator doors to open at the same time, left and right, the doors are fully functional, but they aren't able to be controled at the same time going in different directions. Would any one know how to get the left door to go left at the same time getting the right one to go right to get a relistic elevator door opening slide? the left door goes left already with proper limmits and so does the right. I need them to do so at the same time. The doors are apart of a building or scene I got from daz.com
any help is highly appreciated. Thanks in advance.
Post edited by antwonfilms on
You can create a New Property slider as a "controler" and use ERC-Freeze to save the door positions to that new slider. This is something how the pose control properties on the genesis figures work. For example with arms up-down there the rotations are inverted between the both arms but the pose controler will move both sides. I try to explain how to archive what you asked for with a step-by-step and I hope its easy to follow along.
Not long ago I posted a how-to in a thread with a simmilar question:
How to save teeth translation/scale
The Numeric Parameter Settings Dialog - Documentation Center
thanks so much for the help Syrus. I appreciate that a ton.
