Error during rendering?
Hi guys, I have encountered a weird issue. I never had problems with DazStudio before, it just started happening today. So basically, I cannot render anything anymore, even Iray preview is not working! It worked fine until late afternoon today, when suddenly I couldn't render pictures after some time. Before that, I rendered about 10 of them....
Since then, I decided to wipe my library and do a clean install. Twice. The problem still encounters. The first message I get is: Error during rendering!, and after closing the message and trying again it says: Cannot render, renderer already in use.
If I try to render an empty scene, figures or just switch to Iray preview, it doesn't work. All packages were installed using DIM and everything seemed fine. I'm using 4.11 Beta latest version (Updated after the previous version stopped working) with 2070. Please see the attached log file
  • sterlenejcsterlenejc Posts: 180
    9-06-04 22:05:01.712 *** Scene Cleared ***
    2019-06-04 22:05:04.350 C:/Users/niger/Desktop/MyDazLibrary/data/DAZ 3D/Genesis 8/Male/Morphs/Meipex/Stereo Love/SL_Glutes Inflate Bottom Back.dsf (25,4): Syntax Error - expected ',' or ']'
    2019-06-04 22:05:04.351 C:/Users/niger/Desktop/MyDazLibrary/data/DAZ 3D/Genesis 8/Male/Morphs/Meipex/Stereo Love/SL_Hips Bend Spandex More.dsf (25,4): Syntax Error - expected ',' or ']'
    2019-06-04 22:05:05.455 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5818): Could not find target property for formula: Genesis8Male:/data/DAZ%203D/Genesis%208/Male/Morphs/DAZ%203D/Expressions/eCTRLWink_HD.dsf#eCTRLWink?value in file : /data/DAZ%203D/Genesis%208/Male/Morphs/Zev0/Expression%20Smoother/Wink%20Smoother.dsf
    2019-06-04 22:05:05.456 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5818): Could not find target property for formula: Genesis8Male:/data/DAZ%203D/Genesis%208/Male/Morphs/DAZ%203D/Expressions/eCTRLTriumph_HD.dsf#eCTRLTriumph?value in file : /data/DAZ%203D/Genesis%208/Male/Morphs/Zev0/Expression%20Smoother/Triumph%20Smoother.dsf
    2019-06-04 22:05:05.456 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5818): Could not find target property for formula: Genesis8Male:/data/DAZ%203D/Genesis%208/Male/Morphs/DAZ%203D/Expressions/eCTRLTired_HD.dsf#eCTRLTired?value in file : /data/DAZ%203D/Genesis%208/Male/Morphs/Zev0/Expression%20Smoother/Tired%20Smoother.dsf
    201
    9-06-04 22:05:06.184 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5818): Could not find target property for formula: Genesis8Male:/data/DAZ%203D/Genesis%208/Male/Morphs/DAZ%203D/Expressions/eCTRLExcitement_HD.dsf#eCTRLExcitement?value in file : /data/DAZ%203D/Genesis%208/Male/Morphs/Zev0/Expression%20Smoother/EM8%20Excitement%20Smoother.dsf
    2019-06-04 22:05:06.185 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5818): Could not find target property for formula: Genesis8Male:/data/DAZ%203D/Genesis%208/Male/Morphs/DAZ%203D/Body/FBMHeavy.dsf#FBMHeavy?value in file : /data/DAZ%203D/Genesis%208/Male/Morphs/Zev0/Body%20Mixer/JCM%20Heavy%20UAbdoback.dsf
    2019-06-04 22:05:06.185 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5818): Could not find target property for formula: Genesis8Male:/data/DAZ%203D/Genesis%208/Male/Morphs/DAZ%203D/Body/FBMHeavy.dsf#FBMHeavy?value in file : /data/DAZ%203D/Genesis%208/Male/Morphs/Zev0/Body%20Mixer/JCM%20Heavy%20UAbdoback%20Labdo%20Forward.dsf
    2019-06-04 22:05:06.186 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5818): Could not find target property for formula: Genesis8Male:/data/DAZ%203D/Genesis%208/Male/Morphs/DAZ%203D/Body/FBMHeavy.dsf#FBMHeavy?value in file : /data/DAZ%203D/Genesis%208/Male/Morphs/Zev0/Body%20Mixer/Heavy%20Lower%20Details%20Neg.dsf
    2019-06-04 22:05:06.207 File loaded in 0 min 4.5 sec.
    2019-06-04 22:05:06.207 Loaded file: genesis 8 male dev load.duf
    2019-06-04 22:05:06.410 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-06-04 22:05:06.410 Loaded file: PHMEyelashesLengthUpper.dsf
    2019-06-04 22:05:06.411 Loaded file: PHMEyelashesLengthLower.dsf
    2019-06-04 22:05:06.411 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-06-04 22:05:06.411 Loaded file: PHMEyelashesCurl.dsf
    2019-06-04 22:05:13.571 Total Rendering Time: 1.57 seconds
    P.S: I get about 700 lines of errors about morphs which I'm not even using... I deleted them but they show up in Daz as (!) errors, so I'm ignoring them ATM
  • Richard HaseltineRichard Haseltine Posts: 112,126
    I would suspect a drivr update slipped in this afternoon and is causing the issue. Check that you are using proper nVidia drivers.
    Ok, will check. I was using Quadro in that PC for some time, I got those PRO drivers etc because I connect to that PC remotely and I need openGL support....
    Sound like corrupt content files.
    The others are probably harmless, just cross-links with another product that aren't needed since you don't have the other product.
    In any event, none of that is likely to be linked to a render error.
    But I don't have those files anymore... I wiped my daz directory and did a fresh install. Do you think changing paths would help? It's really getting into me. At least I can get Iray preview working now, but can't render.....
    Thwy must be there, in one of the content directories, for DS to try to read them. The error is from part way through the file.
