Product Library question
Hello all,
Is there anyway to export my product listing from my account into a text or CSV file?
  • NorthOf45NorthOf45 Posts: 5,936
    If you use DIM, select all products from the Installed tab, then right-click anywhere inside and select "Export Selected to CSV". If there are more that you haven't installed, do the same for the other two tabs (Ready to Download, Ready to Install). The popup will show what info can be saved.
  • Richard HaseltineRichard Haseltine Posts: 112,126
    You could also use a modified version of http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/metadata/list_products/start to go directly to the DS database, which would avoid the duplications you'd get from DIM where a product is split across zips.
  • CoXComicsCoXComics Posts: 102
    Worked like a charm! Thank you!
