Morph and Expression Installation Problem
Good afternoon,
I'm having an issue getting several morphs and expressions to install. I've attached some screenshots of what I'm seeing. I've also attempted to uninstall and then reinstall using DIM, but the issue remains the same - these items apparently don't install. Or, to be precise, DIM says they're installed but Daz Studio doesn't seem to think so. In the end, I can't tell if they are or not. Any ideas?
https://imgur.com/a/Hnryxcr
Thank you,
Bob
  • Richard HaseltineRichard Haseltine Posts: 111,348
    Those are showing User categories rather than the Store categories, though it's hard to tell from those screen shots - it would be better to attach them to the forum post directly.
  • retiretomauiretiretomaui Posts: 392
    Only I can't. When I click on the "Image" button, it asks for a URL, not a file upload.
    Actually, when you click on the IMGUR images, they enlarge. I'll attach them below, though. As for the categories, I'm not sure what you mean. That's how the morphs and epressions are popping up in Daz Studio. I haven't done anything to them.
    3440 x 1440 - 833K
    3440 x 1440 - 1M
  • Cris PalominoCris Palomino Posts: 12,963
    https://www.daz3d.com/avow-expressions-for-arabella-7-and-genesis-3-female-s seems to be one of the products you're showing and the description says they are dials. Expected behavior would be to load the figure and with the figure root selected (possibly head will do as well), go to the parameters tab, Pose Controls, Head, Expressions. If there is a folder for it, you will see it under expressions, if not, they will just be in the list of expressions. It is likely the PA may have them color coded. You can dial them up and mix them from here. Some products may have presets to load the expression, but any mixing would be by dials. This Avow set does not indicate presets.
  • TaozTaoz Posts: 10,345
    You should click the "Attach a file" link under the editor to upload files.
    Can you find the files in the Content Library pane, under Daz Studio Formats? Exactly where are the files installed?
    Nope, not in Content Manager. They appear to not be installed, at all.
    Well, that's probably good as they are not - I think - products with user-facing files. Those that I know work by adding new sliders to the figure.
    Okay, this is weird. i just turned DS on and went to the Install pane. Everything looked prepped for install so I did. It's apparently all in. Weird...
